my location widget scale problem
2591
16
02-03-2016 07:08 AM
MathiasEriksson
New Contributor II
I have a my location widget that has the code.
  "locateButton": {
    "geolocationOptions": {
      "timeout": 15000
    "highlightLocation": true,
    "useTracking": true,
    "scale": 1200
the scale command give a perfect scale.
but if I zoom in or out it resets after 15 sekund. ( I can change reset time to what ever I want)
I'm trying to get it to stay at the zoom lvl  the user sets after first positioning.
If i remove scale is goes to maz zoom every 15 seconds
I have try to use :
  "locateButton": {
      "timeout": 15000,
      "setScale": false
    "useTracking": true
but the it zooms in to max and stay the. I can't zoom out.
any one have a any good input on this?
RobertScheitlin__GISP
Mathias Eriksson,
  If you only want the widget to zoom to the defined scale once and then allow the user to change the maps scale as desired from then on then Just add setScale = false in the onLocate function in the widget.js file (line 16):
      onLocate: function(parameters) {
        html.removeClass(this.placehoder, "locating");
        if (this.geoLocate.useTracking) {
          html.addClass(this.placehoder, "tracking");
        if (parameters.error) {
          console.error(parameters.error);
          // new Message({
          //   message: this.nls.failureFinding
        } else {
          html.addClass(this.domNode, "onCenter");
          this.neverLocate = false;
        this.geoLocate.setScale = false;
Mathias Eriksson
   Did this work for you?
MathiasEriksson
New Contributor II
Have been away from the office. trying today but Can't fint the code exemepl you put in the thred.
I think you mean the Widge.js in folder *\inetpub\wwwroot\WAB13DE\Kalmar\widgets\MyLocation
is that correct ?
Mathias,
   It is in the *\inetpub\wwwroot\WAB13DE\Kalmar\widgets\MyLocation\widget.js file. The onLocate function is what you are looking for.
MathiasEriksson
New Contributor II
Line 315 . {
        onLocate: function(e) {
            d.removeClass(this.placehoder, "locating");
            this.geoLocate.useTracking && d.addClass(this.placehoder, "tracking");
            e.error ? console.error(e.error) : (d.addClass(this.domNode, "onCenter"), this.neverLocate = !1)}
My don't look like yours.
Mathias,
    That is because you are using the minified code version in that app and not the developer version. That is not an issue though just make it look like this:
            this.geoLocate.setScale = false;}
MathiasEriksson
New Contributor II
that did onot work so well.
When i add the code line my complete widget disapers.
Mathias,
  Try this then:
            this.geoLocate.setScale = 0;
MathiasEriksson
New Contributor II
did not help that either.
app.sandbyborg.se  Here you can se the app online and IO can send the complete code to you if you like to see so I did not make any misstake.
