Hi I have a 1-M relationshipclass which I want to use to obtain graphs where a user can compare multiple points. I have tried to use the infographic widget with an external data source from the query widget as well as the infographic widget . The main problem am facing is that only one query works at a given time for the infographic wifget . ex: station name , year, month in the query widget . I want to compare multiple points based on the query so that I can study the obtained parameters. Kindly provide the necessary steps to use an existing widget or an advice to customize it . Thank you in advance and hope to hear it from you guys soon
