Move the popup window in WAB?
3503
12
11-27-2019 07:50 AM
CarolinaAguilar_Aravena
New Contributor II
I need a code that allows moving the pop-up window, since when viewing the map this window covers the layers of the map. I need this to better the user experience assistance. I use the code of How To: Enable drag function on an infoWindow pop-up in Web AppBuilder for ArcGIS  but generate this error.
RobertScheitlin__GISP
Carolina,
   The utils.js that step 2 tells you to modify, should look like this.
define([
    'dojo/_base/lang',
    'dojo/_base/array',
    'dojo/_base/html',
    'dojo/_base/sniff',
    'dojo/_base/config',
    'dojo/io-query',
    'dojo/query',
    'dojo/NodeList-traverse',
    'dojo/Deferred',
    'dojo/promise/all',
    'dojo/on',
    'dojo/json',
    'dojo/cookie',
    'dojo/number',
    'dojo/date/locale',
    'dojo/i18n!dojo/cldr/nls/number',
    'dojox/encoding/base64',
    'esri/lang',
    'moment/moment',
    'esri/arcgis/utils',
    'esri/dijit/PopupTemplate',
    'esri/SpatialReference',
    'esri/geometry/Extent',
    'esri/geometry/geometryEngine',
    'esri/geometry/Multipoint',
    'esri/geometry/Polyline',
    'esri/geometry/Polygon',
    'esri/geometry/webMercatorUtils',
    'esri/tasks/GeometryService',
    'esri/tasks/ProjectParameters',
    'esri/tasks/FeatureSet',
    'esri/symbols/PictureMarkerSymbol',
    'esri/urlUtils',
    'esri/request',
    'esri/tasks/query',
    'esri/tasks/QueryTask',
    'esri/graphicsUtils',
    'esri/IdentityManager',
    'esri/arcgis/OAuthInfo',
    'jimu/portalUrlUtils',
    './shared/utils',
    './accessibleUtils',
    './zoomToUtils',
    'dojo/dnd/Moveable',
    'dojo/dom-class',
    'libs/caja-html-sanitizer-minified'
function(lang, array, html, has, config, ioQuery, query, nlt, Deferred, all, on, json, cookie,
  dojoNumber, dateLocale, nlsBundle, base64, esriLang, moment, arcgisUtils, PopupTemplate, SpatialReference,
  Extent, geometryEngine, Multipoint, Polyline, Polygon, webMercatorUtils, GeometryService, ProjectParameters,
  FeatureSet, PictureMarkerSymbol, esriUrlUtils, esriRequest, EsriQuery, QueryTask, graphicsUtils, IdentityManager,
  OAuthInfo, portalUrlUtils, sharedUtils, accessibleUtils, zoomToUtils, Moveable, domClass
Carolina,
   Sounds like you have something missing or out of order in the define array (step 2 in the instructions).
New Contributor II
Do you know how I can solve this error?
Not without seeing your code change, were I can identify your mistake.
New Contributor II
The modifications of the code that generated this error were those shown in the following link: How To: Enable drag function on an infoWindow pop-up in Web AppBuilder for ArcGIS in step 2 and 3, these generate the message presented, of the function "Moveable"
Carolina,
   That is the problem. When those modification are done properly they do Not produce an error. So you are likely make a standard beginners error and adding the new define and making the vars that are linked with those defines out of order.
New Contributor II
Could you help me solve it? What part of code do you need to see what the error is?
Carolina,
define([
    'dojo/_base/lang',
    'dojo/_base/array',
    'dojo/_base/html',
    'dojo/_base/sniff',
    'dojo/io-query',
    'dojo/query',
    'dojo/Deferred',
    'dojo/promise/all',
    'dojo/on',
    'dojo/json',
    'dojo/cookie',
    'dojo/number',
    'dojo/date/locale',
    'esri/lang',
    'moment/moment',
    'esri/urlUtils',
    'esri/request',
    'esri/tasks/query',
    './shared/utils',
    './zoomToUtils',
    'dojo/dom-class',
New Contributor II
I thought my code was the same as yours, but I copy your code and it worked and my problem was solved. Thanks
ЭрикНазаров
New Contributor II
Hello! Please help me! I did everything in accordance with these recommendations, but still nothing comes out. In the file "utils.js "there is no "mo.createwebapp", there is only "e.create a web map." I also changed it there and nothing worked out.
