Map Info Widget Version 2.2.3 - 1/27/2017
2200
01-20-2017 01:18 PM
The purpose of this widget is to provide the user with easy access to basic information about the web map that is being used in the WAB app. This widget was created with WAB DE 2.2 and has been tested in 2.16 with no issues.
Features of the widget:
  • Get current map Extent
    • Projection Coordinates
    • Geographic Coordinates
  • Get map Spatial Reference
  • Get Web Map Information
    • Title
    • Map ID
    • Owner
    • ArcGIS Online Sharing level
    • Tags
  • Get Map Layer Info
    • A list of the unique layer ID's that are assigned to the layers when they are added to the Web Map.
      • Feature Layers
      • Dynamic MapService Layers
If there are any questions/suggestions please let me know!
Thank you,
Chris
Comments
Christopher (And anyone else creating/sharing custom widgets) it would be great if you could include an update date as part of your page name (version is also helpful), similar to how Robert does it https://community.esri.com/docs/DOC-1731-enhanced-search-widget-version-211-080116    so I can tell for sure that it has been updated...and tag it on the resources list...or if I don't mention an update, it will auto update the date so other know.  Based on my email notification, I'm not sure if you up updated the widget or just the documentation.  Just a suggestion.
Thank you for the tip rastrauch‌!
Version history
Revision #:
1 of 1
Last update:
‎01-20-2017 01:18 PM
Updated by:
Contributors
