I've been having a blast playing around with the new Web AppBuilder, and have taken a few cracks at putting together some custom Widgets that I'd like to share with the community. I hope these can assist in everyone's future Mappmaking endeavours!
September 28 2017 : LocalLayerWidget v2.5 released: This major release includes the following enhancements for the widget. Thanks to everyone who's donated!:
Release LocalLayerWidget 2.5 · cmndrbensisko/LocalLayer · GitHub
November 14, 2016: LocalLayerWidget v2.2 released: This major release includes the following enhancements for the widget:
Release LocalLayer v2.2 · cmndrbensisko/LocalLayer · GitHub
May 18, 2016: LocalLayerWidget v.2.0 released: This substantial change for Web App Builder v.2.0. removes the need to edit any core files in the Web App Builder, unlike previous versions. A slight change will still be necessary for the AttributeTable widget to work properly with LocalLayerWidget layers.
Mar 29, 2016: LocalLayerWidget v.1.3.1 released; Contains bugfixes to v.1.3. related to custom rendering for Feature Layers and toggling sublayer visibility in the LayerList widget.
Mar 22, 2016: LocalLayerWidget v.1.3 is now available! (Note the version naming change; Version 1.3 refers to its compatibility with v1.3 of the WAB - This is indeed the latest version of the widget as of March 22, 2016). Be sure to read the github page to see what tweaks need to be made to ensure that everything continues running smoothly in version 1.3 of the Web AppBuilder.
Feb 10, 2015: LocalLayerWidget v.1.5 is now available! This release contains full support for adding Tiled layers to your application directly from ArcGIS Server, in addition to the Basemap, Dynamic, and Feature layers available before. Feel free to grab the widget from our Release page located at https://github.com/cmndrbensisko/LocalLayer/releases.
Feb 2, 2015: LocalLayerWidget v.1.2 is now available! This release provides a great GUI developed by Robert Scheitlin to more easily add Feature, Dynamic, and Basemap layers to your ArcGIS Web AppBuilder Applications. Take it for a spin, and please keep us informed of any bugs or desired enhancements through our Github Issue Tracker located at https://github.com/cmndrbensisko/LocalLayerWidget/issues.
Jan 12, 2015: Note that LocalLayerWidget v.1.1 is now available, which provides Click-To-Identify support and the option to add Feature and Basemap layers in addition to Dynamic layers.
The LocalLayer Widget is intended to allow the direct addition of MapServices to an ArcGIS Web AppBuilder application, without needing to wrap the desired services in an ArcGIS Online/Portal Web Map.
Basically, your basemap will still need to come from Portal/AGOL, but otherwise you just provide direct URLs to your own MapServices in the widget's configuration settings. The MapServices should load and display as usual in the map, and cooperate with the Legend, LayerList, and Attribute Table widgets. Click-To-Identify functionality won't work currently, though, because the current WAB implementation relies on Portal for all the popup info. As stated in the January 12th 2015 release, popups are fully customizable. Note that it's not an in-panel widget, so you'll need to follow a few extra steps in the project's Readme file.
Let's make Mapps accessible for everyone! With an eye on WCAG compliance, the Accessifizr Widget is designed to help make web applications keyboard navigable without having to modify core application code and UI.
https://github.com/cmndrbensisko/AccessifizrWidget
Information about how to configure this widget is available in the core Accessifizr.js library project available here, but the gist is that you create a JSON-based 'roadmap' detailing the keyboard navigation of your web application, and how it should change in response to users entering modal menus, hitting the escape button, etc. For applying descriptive alternate text to page elements, the widget leverages dojo's built-in internationalization support to specify multilingual alternate text strings. The end result is a web app that, hopefully, is a bit easier to use for people with mobility or visual challenges.
I have a feeling this was due to a change I made. I'm going to copy/paste this into our issue tracker and assign it to myself; Your service will be very helpful in finding the best way to implement this. Thanks Barnaby.
Thanks, Adam. You know, when I add "visible": false to the \client\builder\predefined-apps\default2DApp\config.json, I can't get ANY service added using your widget to display in the WAB app.
"uri": "widgets/LocalLayer/Widget",
"visible": false
Barnaby all you have to do is click the eye in the upper right corner of the widget to enable the widget in that particular app.
Got it!
Thanks, Robert!
Thanks for the info, Adam!
Cheers,
Barnaby
Hi Adam,
I'm running Server 10.3, Web Adaptor, and WAB Dev 1.0 on Win Server 2012 R2 x64. Portal has not been installed. All my services are indeed dynamic with no tile caches. None of the services are secured.
Hopefully Robert's widget will include capability for setting initial visibility (like in Flex Builder).
I am trying to duplicate functionality available in this Flex web viewer which includes several of Robert's widgets:
National Map of Surficial Mineralogy
For a service that has many layers and sublayers that are not "on" by default (as set in mxd), such as the "Regional Studies" service shown in that image posted above, when one of the layers is turned on, the top sublayer of ALL layers will become visible, and they cannot be turned off individually. Only when the Regional Studies service itself is turned off will these sublayers become invisible.
Barnaby,
I know you said you are adding this layer a dynamic, but does this map service have tiles (cached)? I have seen the behavior you are talking about with this map service.
http://services.arcgisonline.com/arcgis/rest/services/Demographics/USA_Tapestry/MapServer
Hi Robert,
As I wrote to Adam (see above), all my services are dynamic with no tile caches. They are mainly rasters (ERDAS Imagine .img) with pyramid files.
Cheers,
Barnaby
Barnaby,
What server version and service pack?
Robert,
From my post to Adam above:
I'm running Server 10.3, Web Adaptor, and WAB Dev 1.0 on Win Server 2012 R2 Standard x64. Portal has not been installed.
I have two ArcGIS for Server 10.3 patches installed:
Patches and Service Pack - Esri Support
Cheers,
Barnaby
