Latest Print Widget to Print Map and Search Results
662
09-26-2019 11:43 AM
BingJing
I am looking for a Print Widget that can be customized to print results data as well as highlighted parcel map and (from search widget).  Shall I start with the original print widget that comes with the WAB, or some enhanced version that I can build upon? Thank you!
Print Plus Widget Version 1.1.6 July 12, 2015  (LIVE Preview does not work)
LeoLiu1
Hi Bing Jing,
Are you going to print your highlighted parcels in a single map, or one map per parcel (feature map)?
If you only need single map, I would suggest to use Report class:
Report class—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Otherwise you probably need GP service + Data Driven Pages/Map Series to print feature maps in a report.
Leo.
BingJing
I will try the Report class. Thank you Leo.
