All,
Here is a list on my currently available Web AppBuilder widgets for Web AppBuilder 1.x.
Here is a list of my mixin classes for the Web AppBuilder 1.x widgets.
Here is my entire application, which includes my Acme Widget. The Acme Widget is invisible, but adds key functionality to the basic Web AppBuilder viewer and modifies the appearance and/or behavior of several Esri Widgets (without editing the Widgets themselves).
Changes and Bug Fixes, May 5, 2015
Changes and Bug Fixes, May 3, 2015
Web AppBuilder Application
All documentation is now included in the Doc folder in the zip file.
This is a live preview site for all of the above (except Anvil):
My To Do List:
Larry,
Thank you for the awesome work in WAB!
Do you have any documentation on how to host your full WAB application?
Larry,
Your repository for WAB fixes and widgets is awesome! I'd like to second Larry Phelp's question regarding how to host your full WAB app that you've made downloadable. I've tried modifying the main config.json file to point to our portal and changed the app ID's, but was curious what other steps are necessary to get your app working locally.
Regarding your Hamilton Co app - we are especially interested in your WelWhatDisHelpAbout widget. I've been able to incorporate all of the dependencies and config files correctly ( i think), acme included, to get it to function about 90% correctly. Just need to figure out how you destroyed the "Help" panel that tries to open in your Hamilton app but gets blocked. It persists in my implementation (screenshot attached). It only disappears when clicking the acknowledgement button, but shows again if the user selects the "?" help icon. Any advice for getting past this would be greatly appreciated - hoping its not simply a WAB version issue ( I'm using WAB 1.3). Thanks for all your work with these widgets, and any help/guidance you might be able to provide.
Ryan
Hi Ryan I'm trying to make the same with my test application.
What I have to modify to run this widget at startup? I just installed Anvil and I copied the folder WelWhatDisHelpAbout inside my application.....
Naty
Hi Ryan,
Please where you able to figure out a solution to your question above?, regarding the "Help Panel" still showing. If you did find a solution, can you kindly assist a me in solving mine too.
Thank you
Baba
Hi Baba/Natasha,
Sorry, I am not of any help here. I was unable to disable the Help Panel from opening and have since moved on to other development. thanks
Ryan
Hi Ryan,
I also tried removing that help panel but I wasn't able to fully do so. I am assuming it has to do with the different versions. Has anyone else been successful in removing the panel? Other than that I have this widget working beautifully in version 2.4.
Tim
Thanks for the brilliant App Larry,
The custom widgets are very useful and adds great functionality to the Web App.
I am trying to explore the full app by deploying it on local server. But I have some difficulties in the deploying of the full app on to my server (similar to Ryan N. and Larry P.)
I have ArcGIS Online organisational account with OAuth2. I followed the instructions for deploying the app on local server from the readme.html As per the documentation about the deploying the app, default proxy settings must be overwritten in config.json followed by adding and registering the app on AGOL account.
At present, my organisational network setup did not use proxy (use multilevel firewalls though), hence cannot follow the steps given in the documentation.
How this can be achieved?
Amit
Hi Larry,
I'm new to web appbuilder and I'm trying to use your user preferences widget. I downloaded the zip and loaded it into my app but I'm having issues. I'm getting a settings error. When I downloaded the user preferences widget , the setting folder is empty. Is there supposed to be a setting.js and setting.html in the settings folder?
Keisha
Hi Larry, we are interested in testing your Print Plus Widget in our applications, but the FTP link seems to be broken. Do you have an alternate location where we could find the widgets?
Thanks!
Hi all,
I know that Larry Stout , who did great working on these custom widgets, changed jobs a while back (~ Spring '16) and doesn't get on GeoNet as often, so many of the links to the original location have been broken. Some of these were uploaded #WebAppBuilder for #ArcGIS - Custom widgets directory and those download links still work.
NOTE: Because these were uploaded by Larry, they should still be ok to download (although maybe an older version). I'm including the link to that github widget index here (and will also put it on /blogs/myAlaskaGIS/2016/03/09/web-appbuilder-developer-edition-customization-resource-list?sr=search... ) but with out Larry's permission, I don't feel that I (or anyone) should upload them for distribution/download --- unless value added info or updates are included, etc. I sent an email to Larry but haven't heard back yet. Please respect that until we hear otherwise. (my opinion)
EDIT 2/18/2017 - See my first comment at the top (or in the resource list) for new download links.
