How do I change the basemap programmatically?
4329
7
12-21-2019 05:38 PM
JoseVidal
New Contributor III
I am building a custom widget for WAB. To start with, I just want to build a button that switches between the 'streets' and the 'topo' basemap.
I created a working widget and in it I have this code:
let newMap = new Map("map", {
  basemap: "streets",
  center: [-105.255, 40.022],
  zoom: 13
console.log("newMap")
console.log(newMap)
this.map = newMap
Which creates a new Map, and does not generate any errors, but also does not change the map.
I am guessing I need to do more than just `this.map = newMap`. But, what?
There is no documentation on this.
shaylavi
Jose,
You should not recreate the map object unless you plan to display multiple map views.
To change a basemap you use the existing map object and use the function setBasemap
map.setBasemap("name_of_the_basemap");
alternatively, you can use the toggle widget that has this functionality built-in -
Basemap Toggle | ArcGIS API for JavaScript 3.31
or the basemap gallery widget, which is similar -
Basemap gallery | ArcGIS API for JavaScript 3.31
Shay.
Shay
RobertScheitlin__GISP
Here is a link to a thread about issues trying to use the JS API basemap toggle widget in WAB.
https://community.esri.com/thread/161760#comment-534257
Here is how we switch a basemap in the custom Local Layer widget.
var bmLayerObj = {
  url: url,
  isReference: false
var _newBasemap = new Basemap({
  title: "blah blah",
  layers: [new BasemapLayer(bmLayerObj)]
var _basemapGallery = new BasemapGallery({
  showArcGISBasemaps: false,
  map: this.Map
_basemapGallery.add(_newBasemap);
_basemapGallery.select('defaultBasemap');
_basemapGallery.destroy();
JoseVidal
New Contributor III
That worked! Thanks!
I only had to change line 12 to: map: this.map. Uppercase this.Map does not work.
But, I am executing a printtask right after changing the basemap and the print uses the old map. I am guessing it is because I have to wait until the basemap has changed before a call the printtask.
Is there a way to get a callback (setup a .then()) for after the basemap changes?
JoseVidal
New Contributor III
Thanks! That worked.
JoseVidal
New Contributor III
I used the line:
this.map.setBasemap("topo");
but, it does not do anything. The map remains the same. It does not produce an error either.
I will try Scheitlin's solution next.
Adarshvarma
Jose,
it sets the base map at a particular zoom level, but again it vanishes after we change the zoom level
