How can I make the legend dimensions smaller? Too much white space
2651
12
10-04-2017 02:34 PM
MelissaTraverso
New Contributor III
Hi I would like to trim the dimensions of my legend widget to be smaller. How do I do this? Currently there is too much white space and it covers up important parts of the map when you filter or zoom. I realize you can X out of it but this is inconvenient if you don't have the legend memorized as you're filtering or using another tool.
Melissa
SaffiaHossainzadeh2
New Contributor II
Hmm...that doesn't work for me. I added line 205 to the config.json:
I similarly added "height":125 to a position property in a widgetPool section of config.json. And nothing happened. I tried adding a new position property at other spots inside the legend widget (like after line 177), but none of my attempts were successful. Am I missing something?
Just for completeness, I was able to adjust the legend size as I intended using an entirely different method. I added the following css tag in the index.html file:
.jimu-pocket-panel {
  height: 95px !important;
  width: 220px !important;
It would not work without the !important part.
RobertScheitlin__GISP
Saffia,
  You are heading in the wrong direction. Here is what I am talking about. (line 6 was added).
        "position": {
          "left": 205,
          "top": 45,
          "relativeTo": "map",
          "height": 125
        "placeholderIndex": 1,
        "id": "_8",
        "version": "2.11",
        "closeable": true,
        "uri": "widgets/Legend/Widget",
        "name": "Legend",
        "label": "Legend_2",
        "config": "configs/Legend/config__8.json"
SaffiaHossainzadeh2
New Contributor II
That didn't work for me straight away. I will try some more though.
Thanks a lot for your input!
