Extracting data on map in CSV/Feature Class/KMZ format
1167
08-28-2017 02:59 AM
akshayloya
Occasional Contributor II
I have Portal for ArcGIS and ArcGIS Server 10.5 federated. I have published my feature services using ArcMap 10.5. I have developed an application using web app builder. I want tool to extract data on my map in different formats. Somehow extract data under analysis seems not working for me.
Kindly help.
Regards,
Akshay
RobertScheitlin__GISP
Akshay,
   Because there is an OTB widget for this no one has developed a custom one. You need to work with Esri support to figure out why the data extract widget is not working for you.
akshayloya
Ok. Is there any way to extract data other than that based on different spatial reference in CSV/FGDB/KML format ?
There is not.
