Export graphics to KML/KMZ
7033
04-09-2015 08:47 AM
GeorgeOulton1
New Contributor III
Hello All
Has anyone tried exporting graphics created in the drawing widget for WAB 1.1 to KMZ or KML?
Should this happen server-side or is it possible within the javascript?
Any feedback would be wonderful!
Thanks
George
OwenEarley
Occasional Contributor III
You could do this client side you would just need to write a javascript function that converts the graphics into KML. Check out the KML Documentation Introduction
You would need to convert the ESRI graphic geometry object into the equivalent KML geometry:
  • ESRI Point - KML Point
  • ESRI Polyline (path) - KML LineString
  • ESRI Polygon - KML Polygon
GeorgeOulton1
New Contributor III
Thanks for the reply Owen
I was hoping to have it run along those lines, but my point of confusion is around the drawbox dijit. It seems all the graphics are added there and not to a graphics layer and I'm not too sure on how the drawbox works, is it like a graphics layer?.
UPDATE:
I see, I can inherit the map and get the current graphics layer from the map and then work from there.
Thanks
JeremieCornet1
Hi George,
The drawBox dijit use a graphic layer.
You can access the graphicLayer in the draw widget with :
this.drawBox.drawLayer
Maybe you could add your kmz export functionnality to the non-official eDraw widget
magis-nc/esri-webappbuilder-widget-eDraw · GitHub
This widget has allready a "json export/import" functionnality.
TylerArmstrong
I know this is a very old post, but did anybody have success adding kml/kmz export functionality to the draw (or eDraw) widget?
GeoguichetGeoguichet
New Contributor III
Hello.
I added export tool in the draw widget, at client side.
Because my maps aren't in WGS84, I needed to use 'esri/geometry/projection'.
It's perhaps not so optimal if there are very much graphics, but in my case the drawings done with Draw widget are not so many.
So I'm looping in this._graphicsLayer.graphics and I construct the KML as a string, based on the specification and analyzing ...geometry.geoType in order to create Point, LineString or Polygon objects.
Example:
kmlContent = kmlContent
+ " <name>" + graphics.attributes.OBJECTID + "</name>\r\n"
+ " <styleUrl>#drawing" + (i + 1) + "</styleUrl>\r\n";
for (var j = 0; j < geometry.paths.length; j++) {
+ " <LineString>\r\n"
+ " <altitudeMode>clampToGround</altitudeMode>\r\n"
+ " <coordinates>\r\n";
for (var k = 1; k < geometry.paths.length; k++) {
var projPt1 = new Point({ x: geometry.paths[k-1][0], y: geometry.paths[k-1][1], spatialReference: mySpatialReference });
var projPt2 = new Point({ x: geometry.paths[0], y: geometry.paths[1], spatialReference: mySpatialReference });
var geoPt1 = projection.project(projPt1, wgsSpatialReference);
var geoPt2 = projection.project(projPt2, wgsSpatialReference);
kmlContent = kmlContent + " " + geoPt1.x + "," + geoPt1.y + ",0 "
+ geoPt2.x + "," + geoPt2.y + ",0\r\n";
+ " </coordinates>\r\n"
+ " </LineString>\r\n";
geometry is this._graphicsLayer.graphics.geometry;
At the end I use the download function that exists in CSVUtils:
return CSVUtils._download(filename, kmlContent);
