Enable Pop-up
5600
05-28-2015 02:45 PM
RickeyFight
MVP Regular Contributor
I am adding a layer when a widget loads.
I am trying to have popups enabled when it loads.
I cannot find the script to enable popup on load.
I hope this is an easy option.
XiaodongWang
Rickey,
Try the code below:
     // require('jimu/LayerInfos/LayerInfos')
     // testCode funciton is in Windget's context;
      testCode: function() {
        var url = "http://sampleserver6.arcgisonline.com/arcgis/rest" +                        "/services/CommercialDamageAssessment/FeatureServer/0";
        var featureLayer = new FeatureLayer(url);
        this.map.addLayer(featureLayer);
        featureLayer.on('load', lang.hitch(this, function() {
          LayerInfos.getInstance(this.map, this.map.itemInfo).then(lang.hitch(this, function(layerInfos) {
            var featureLayerInfo = layerInfos.getLayerInfoById(featureLayer.id);
            featureLayerInfo.loadInfoTemplate().then(lang.hitch(this, function() {
              featureLayerInfo.enablePopup();
LayerInfos is data structure of WAB that reflects the relationships of all operational layers of map. After add a layer to the map, you can get its 'LayerInfo' using layerId by layerInfos.getLayerInfoById(), and then using layerInfo to control popup(loadInfoTempalte and enable popup).
StanMcShinsky
Occasional Contributor III
​typically you configure and enable pop ups through AGOL web map. I am assuming you are adding this layer after the map is loaded?
-Stan
RickeyFight
Stan,
Yes I am using same concept as the local layer widget to load the layer.
XiaodongWang
Rickey,
Try the code below:
