Completely remove tool tip from eSearch?
754
09-11-2020 08:42 AM
MartinOwens1
Occasional Contributor II
I have added showTooltips: false; to almost every place I can think of in the widget.js and can't seem to remove the tooltip from the graphic select option. Any help would be appreciated.
RobertScheitlin__GISP
Martin,
   Glad You found a way while I was away. The ways to do this in code is In the Widget.js _initDrawBox function.
this.drawBox.drawToolBar._options.showTooltips = false;
MartinOwens1
I realized I can just set the display through the CSS as none.
.map .esriMapTooltip {
   display: none !important;
Martin,
MartinOwens1
Nicely done Robert! I was missing the _options.
