Closest Facility Widget for Web AppBuilder
5662
8
01-12-2016 10:50 AM
Here's a port of my FlexViewer Closest Facility Widget for the Web AppBuilder.
http://www.arcgis.com/home/item.html?id=9a81bb2f4d7c416d8eaca4fe2864c910
Try it live here or get the code here.
Changes:
v1.1.5, 1/21/2016:
  • Fixed a problem in which some facilities datasets with lots of attributes confuse the solver. Create a copy of the facilities, but without attributes, before sending to the solver.
v1.1.1, 1/15/2016:
     * Settings page: animation duration field now forces the value to be a nonnegative integer
     * Displays a busy indicator while the server runs the solver
Comments
This looks awesome thank you!
This is really amazing!
This is great, well done!
This is really cool.  I tried deploying on WAB 2.1, but it doesn't seem to be working.  Have you had any luck deploying on newer versions?
Greg,
Sorry for the very, very late reply. I was able to use the widget fine in WAB 2.2. Did you make sure to copy the widget "ClosestFacility" folder into WAB's stemapp > widgets directory before creating a new application?
WAB CF widget in action
Ok I did get it working.  After extracting, I renamed the folder "ClosestFacility." It was previously called closest-facility-wab-js-master.
Thanks, Greg. I've updated the GitHub readme to include this renaming step.
Version history
Last update:
‎01-12-2016 10:50 AM
Updated by:
Contributors
