Change Attribute Table widget's column width by field name
1005
08-13-2020 04:17 AM
DávidGregor
New Contributor II
I would modify the column width to get  automatically resized to content, what is maybe too much. But  a hardcoded (specify field names) version would be better. Just i cannot find my way to the columns creation.
Any idea to stop long string's breakings in the cells?
This code is just theoretical:
aspect.around(this.grid, "renderColumns", function(original) {
return function(object) {
var column = original.apply(this, arguments);
console.log(columns);
if(object['SDE.TABLE.FIELD']){
console.log('found');//object is the row data object so change the field name to your own
html.addClass(columns, 'wideColumn');
return columns;
console.log("run");
this.grid.refresh();
style:
.wideColumn {
width:400px !important;
DávidGregor
New Contributor II
Totally hardcoded option:  add this to the AT widget's style.ccs:
the number is your cloumn
.dgrid-column-field3{
  width500px !important;
DávidGregor
New Contributor II
in _FeatureTable.js  you can console.log(header)
and you can see the classes of your headers, so you can be more specific in the css.
like this:
capital letters are sample values for the scheme.
.field-SDE-TABLE-FIELD{
  width600px!important;
