Bad formatting export to CSV in WAB
3220
6
05-27-2016 01:54 AM
MarkétaHolá
New Contributor II
Hello,
I use WAB Developer v. 2.0. I have a problem with export to CSV in Attribute Table Widget and e-Search Widget. After export to Excel is not table formatted. Table contains only one column with all attributes, which are separated by a comma (see video). I searched in this forum, but I didn't find any solution for my problem.
Is there any solution?
Thanks.
DanPatterson_Retired
video couldn't be decoded on Windows 10 and Edge browser at least
RobertScheitlin__GISP
Kamil,
   I use the same CSV code as the attribute table widget so that is why they are behaving the same. This looks like a language based issue. Does your local use a different character for the comma?
MarkétaHolá
New Contributor II
We are using "," for the decimal number (for example 5,25).
Windows 7 Settings - Region and language:
MarkétaHolá
New Contributor II
...and for the comma we use character " , ", too.
Kamil,
  The only thing I can recommend is that you contract your local esri support contact to report this issue.
MarkétaHolá
New Contributor II
Robert,
ok, thank you.
