Anvil Widget Question
3824
8
06-04-2016 06:14 PM
TimHayes1
Occasional Contributor III
Headless? Invisible? Sounds intriguing. Has anyone used this custom widget by Larry? If yes, how/what have you used it for? I cannot find any examples.
AdrianWelsh
MVP Honored Contributor
Tim,
It might be a good idea to tag Larry Stout​ and post a link to his widgets page: Larrys Custom WAB Widgets and More
Maybe he can chime in on example pages for Anvil?
RobertScheitlin__GISP
Tim,
  Larry provides to widgets that show the use of the anvil widget:
Anvil Map Tips Widget Version 1.1, May 25, 2015
Anvil Bookmarks Widget Version 1.1, June 11, 2015
LefterisKoumis
Hello Robert. Do you know I can get Larry's widgets? All the link I tried so far do not work.
Thanks.
Lefteris,
   No, I don't have access to them anymore either. Maybe someone downloaded them and share the downloaded file with you though.
RebeccaStrauch__GISP
As mention in the comments for my resource list, I think I have downloaded them all...just want to check to see if we have permission.  If Larry says fine, I'll try to get them all uploaded.
LefterisKoumis
ok. thank you.
RyanKelso
Robert pointed out the map tips example - I use it for map tips in my app.  I like the idea of using an "invisible" widget to invoke customizations instead of modifying the core app files.
deleted-user-CQZbjNeBXm49
Hi All,
As anyone used this "Anvil Widget" for the "WelWhatDisHelpAbout Widget" only to trigger it at start up as I have tried with no success......
Baba
