Aloha Threat Zone Widget Version 2.9 - 09/27/18
166267
10
02-29-2016 10:54 AM
Live Preview Site
Web AppBuilder for ArcGIS | Help - Aloha Threat Zone widget
Links to sample pas files:
SULFURYL CHLORIDE.pas
ACETYL BROMIDE.pas
CHLORINE.pas
List of the latest enhancements and changes:
  1. Updated for WAB 2.9
  2. Fixed issue with importing widget into Portal.
Older Enhancements and fixes:
  1. Fix bug where threat zone footprint was not drawing at the proper scale
If you are an emergency responder than you are likely familiar with NOAA'a ALOHA
(Areal Locations of Hazardous Atmospheres) is a modeling program that estimates threat zones associated with hazardous chemical releases, including toxic gas clouds, fires, and explosions.
NOAA has developed ALOHA ArcMap Import Tools which allow you to import ALOHA threat zones
(also called footprints) into ArcMap 9.x and 10.x.
This widget allows for the plotting of the Aloha threat zones in Web AppBuilder.
This widget does not model or generate the chemical plume, It only imports the Aloha .pas
file and parses the file to plot the data in Web AppBuilder.
Features:
1. Ability to parse and plot a Aloha .pas file in Web AppBuilder at a user specified point of origin.
2. Add multiple Aloha threat zones to the viewer simultaneously.
3. Ability to turn on and off the visibility of individual threat zones in the app and adjust the transparency of all footprints.
4. Display a legend and metadata for each threat zone in the widgets results.
5. Zoom to the threat zone by click on the widget result. You also have the ability to specify the zoom percentage of the graphics extent for zooming (i.e. 1.2 means zoom to 120% of the graphics extent).
Comments
cool widget, thanks for sharing.
question:
does the model factor current wind into the model?  if not, that's seems as key as the chem type, for example.
Nolan,
   That is a NOAA Aloha model specific question. But yes the Aloha model can take into account wind and even be configured to use a weather station wind info.
Hello Robert
I added this widget to my WAB app in Portal for ArcGIS but I get "Create widget error" when trying to use it.  What could be causing this error?
I'll trully appreciate your help.
What version of Portal are you attempting to add it to? What is the error that show in your browsers web console?
This is from the browser consoleWe are using Portal 10.6.1
When you added the widget did you name it "AlohaThreatZone"? The widget is looking for the list.js file in the widgets/AlohaThreatZone/ folder and if you named the widget differently then this will cause the error you are seeing.
I did all the process of adding the widget again and still get the same error. I have added the images of all the precess.
Folder copiedInside FolderAdding widgetWidget Error 2
Ermelinda,
  Sorry. I now remember a coding change I had to make to some of my other widget to get past this error. I will get a new version out ASAP that is Portal compatible.
Hello Robert.
I truly appreciate your support on this. I will anxiously be waiting for the update.
Regards,
Ermelinda
Version 2.9 of the widget is now available.
Version history
Last update:
‎02-29-2016 10:54 AM
Updated by:
