Alias for column Name
732
08-06-2015 06:23 AM
TerryGustafson
Occasional Contributor II
I have edited the following code to splice the fields I don't want and round the offset fields to 3 places..  Not I would like to ensure all of the Route ID fields are named Route and the MEAS fields are named Offset.  Here is the current code.  Is there anyway to create an alias for these column names?
'jimu-gp-resultrenderer-base jimu-gp-renderer-table',
function(){
this.inherited(arguments);
var fields = [];
if(this.value.fields){
this.value.fields;
else if(this.value.features && this.value.features.length > 0){
for(var p in this.value.features[0].attributes){
fields.push({
      fields.splice(0, 1);
      fields.splice(2, 2);
var columns = array.map(fields, function(field){
return {
label: field.name,
          field: field.name
var data = array.map(this.value.features, function(feature){
feature.attributes.Offset = Math.round(feature.attributes.MEAS * 1000)/1000;
return feature.attributes;
memStore = new Memory({
data: data
this.table = new OnDemandGrid({
columns: columns,
        store: memStore
this.domNode);
function(){
this.table.startup();
RobertScheitlin__GISP
MVP Esteemed Contributor
Terry,
  Something like this should work then:
    var retval = {
        label: field.name,
        field: field.name
    if(field.name === "Route ID"){
        retval.label = "Route";
    if(field.name === "MEAS"){
        retval.label = "Offset";
    return retval;
Terry,
    var retval = {
        label: field.name,
        field: field.name
    return retval;
TerryGustafson
that is exactly what I needed, thank you so much!!
