Removing the calculation of area/length in the Screening Widget report?
2161
01-31-2019 04:55 PM
MartinOwens1
I'm curious if anyone knows how I might be able to remove the calculation in the report for certain layers. I've been able to identilfy them by the feature layer ID and simply hide the calculation in the info report summary "widget panel" but can't seem to figure out how to remove it from the printed report.
If possible I would like to remove the entire column for the calculated area for certain layers.
Any help would be great.
RobertScheitlin__GISP
Martin,
   Well that took some digging... You will need to edit the widget.js _getProcessedPrintData:
Line 255 - 257 are the original but if this is one of those layer you need to hide the area for then replace with lines 258 - 259.  Also line 89 has to be remove for your specific layer as well. I did not write any evaluation code for you this is just showing what needs to change to remove the area column from the report.
     * This function is used to get the data needed for printing the report
     * @memberOf Screening/Widget
    _getProcessedPrintData: function () {
      var dataForReport, areaOfInterestText, areaOfInterestValue, aoiTextTemplate,
        aoiText, printMap, id, unableToAnalyzeText, showUnableToAnalyzeText,
        summaryTableMeasurement;
      dataForReport = [];
      areaOfInterestText = this.nls.reportsTab.aoiInformationTitle;
      if (!domClass.contains(this.aoiFeetUnitAreaContainer, "esriCTHidden")) {
        areaOfInterestValue = this.aoiFeetUnitAreaContainer.innerHTML;
      } else if (!domClass.contains(this.aoiMilesUnitAreaContainer, "esriCTHidden")) {
        areaOfInterestValue = this.aoiMilesUnitAreaContainer.innerHTML;
      } else if (!domClass.contains(this.aoiMetersUnitAreaContainer, "esriCTHidden")) {
        areaOfInterestValue = this.aoiMetersUnitAreaContainer.innerHTML;
      } else if (!domClass.contains(this.aoiKilometersUnitAreaContainer, "esriCTHidden")) {
        areaOfInterestValue = this.aoiKilometersUnitAreaContainer.innerHTML;
      } else if (!domClass.contains(this.aoiHectaresUnitAreaContainer, "esriCTHidden")) {
        areaOfInterestValue = this.aoiHectaresUnitAreaContainer.innerHTML;
      // Add AOI text on top of the report
      if (this.reportDijit.Date) {
        aoiTextTemplate =
          "<div class='esrCTAOIInfoDiv'>" +
          // Title
          "<div class='esriAOITitle'>" +
          "<input class='esriCTAOITitleInput' type='text' value='" + areaOfInterestText + "'>" +
          "</div>" +
          // Area
          "<div class='esriCTAOIArea'>" +
          "<input class='esriCTAOIInputArea' type='text' value='" + areaOfInterestValue + "'>" +
          "</div>" +
          // Date
          "<div class='esriCTPrintLocaleDateDiv'>" +
          "<input type='text' class='esriCTLocaleDateInputTitle' value='" +
          this._getDate() + "'>" +
          "</div>" +
          "</div>";
      } else {
        aoiTextTemplate =
          // Title
          "</div>" +
          // Area
          "</div>" +
          "</div>";
      aoiText = {
        title: "",
        type: "html",
        data: aoiTextTemplate
      dataForReport.push(aoiText);
      //add Map at the top in the report
      printMap = {
        addPageBreak: true,
        type: "map",
        map: this.map,
        printTemplate: this._getPrintTemplate()
      dataForReport.push(printMap);
      dataForReport.push({
        "type": "note",
        "addPageBreak": false
      //Impact summary table
      var impactSummaryTable = {
        title: this.nls.reportsTab.summaryReportTitle,
        addPageBreak: false,
        type: "table",
        data: {
          "showRowIndex": false,
          "maxNoOfCols": 4,
          "rows": [],
          "cols": [this.nls.common.name,
          this._getAggregatedColTitle("esriGeometryPoint"),
          //this._getAggregatedColTitle("esriGeometryPolygon"),
          this._getAggregatedColTitle("esriGeometryPolyline")
      for (id in this._printData) {
        var data, reportTable, matchedIndex, temp, aggregatedObj, aggregatedId, impactArray,
          impactSummaryAggregatedValue, selectedUnitValue;
        data = this._printData[id].info;
        impactArray = [];
        // no results found
        if (data.rows && data.rows.length > 0) {
          // fields off
          // configure check && layer invisible
          if (data.cols && data.cols.length > 0) {
            impactArray = [data.title];
            matchedIndex = [];
            aggregatedObj = {};
            for (var i = 0; i < data.rows.length; i++) {
              //if current index is not found in matched index then search array of that index
              if (matchedIndex.indexOf(i) < 0) {
                temp = this._getArrayIndex(data.rows, data.rows[i]);
                aggregatedObj[i] = temp;
                matchedIndex = matchedIndex.concat(temp);
              //if all index are matched break loop
              if (matchedIndex.length === data.rows.length) {
                break;
            var aggregatedData = {
              "showRowIndex": true,
              "rows": [],
              "cols": lang.clone(data.cols)
            //based on selected unit add col
            aggregatedData.cols.push(this._getAggregatedColTitle(this._printData[id].geometryType));
            for (aggregatedId in aggregatedObj) {
              var newRowInaggregatedData = lang.clone(data.rows[parseInt(aggregatedId, 10)]);
              selectedUnitValue = this.analysisUnitSelect.get('value');
              switch (selectedUnitValue) {
                case "Feet":
                  newRowInaggregatedData.push(
                    this.getSum(this._printData[id].feetUnitInfo,
                      aggregatedObj[parseInt(aggregatedId, 10)]));
                  break;
                case "Miles":
                    this.getSum(this._printData[id].milesUnitInfo,
                  break;
                case "Meters":
                    this.getSum(this._printData[id].metersUnitInfo,
                  break;
                case "Kilometers":
                    this.getSum(this._printData[id].kilometersUnitInfo,
                  break;
                case "Hectares":
                    this.getSum(this._printData[id].hectaresUnitInfo,
                  break;
              aggregatedData.rows.push(newRowInaggregatedData);
            if (aggregatedData.rows && aggregatedData.rows.length > 0) {
              /*sort data in descending order so that rows for which measurement are not to be shown
              will be shifted to bottom*/
              aggregatedData.rows = aggregatedData.rows.sort(this._sortFeatureArray);
              //if last col in row have value 0 show N/A
              aggregatedData.rows = array.map(aggregatedData.rows,
                lang.hitch(this, this._setNotApplicableRows));
              aggregatedData = this._addCommaToAreaAndLengthColumn(aggregatedData, this._printData[id].geometryType);
              reportTable = {
                title: data.title,
                type: "table",
                data: aggregatedData
              dataForReport.push(reportTable);
                case "Feet":
                  if (this._printData[id].geometryType !== "esriGeometryPoint") {
                    impactSummaryAggregatedValue =
                      dojoNumber.format(this.getSum(this._printData[id].feetUnitInfo), {
                        places: 2
                  } else {
                      dojoNumber.format(this.getSum(this._printData[id].feetUnitInfo));
                  break;
                case "Miles":
                      dojoNumber.format(this.getSum(this._printData[id].milesUnitInfo), {
                        places: 2
                  } else {
                      dojoNumber.format(this.getSum(this._printData[id].milesUnitInfo));
                  break;
                case "Meters":
                      dojoNumber.format(this.getSum(this._printData[id].metersUnitInfo), {
                        places: 2
                  } else {
                      dojoNumber.format(this.getSum(this._printData[id].metersUnitInfo));
                  break;
                case "Kilometers":
                      dojoNumber.format(this.getSum(this._printData[id].kilometersUnitInfo), {
                        places: 2
                  } else {
                      dojoNumber.format(this.getSum(this._printData[id].kilometersUnitInfo));
                  break;
                case "Hectares":
                      dojoNumber.format(this.getSum(this._printData[id].hectaresUnitInfo), {
                        places: 2
                  } else {
                      dojoNumber.format(this.getSum(this._printData[id].hectaresUnitInfo));
                  break;
              //if only point/line aoi then show N/A in area/length col
              if (this._aoiGraphicsLayer.graphics.length === 0) {
                summaryTableMeasurement = this.nls.reportsTab.notApplicableText;
              } else {
                if (impactSummaryAggregatedValue < 0.01 && impactSummaryAggregatedValue !== 0) {
                  summaryTableMeasurement = " < " + dojoNumber.format(0.01) + " ";
                } else {
                  summaryTableMeasurement = impactSummaryAggregatedValue;
              switch (this._printData[id].geometryType) {
                case "esriGeometryPoint":
                  impactArray = impactArray.concat(
                    impactSummaryAggregatedValue, this.nls.reportsTab.notApplicableText,
                    this.nls.reportsTab.notApplicableText);
                  break;
                case "esriGeometryPolygon":
                  // impactArray = impactArray.concat(
                  //   this._printData[id].featureCount, summaryTableMeasurement,
                  //   this.nls.reportsTab.notApplicableText);
                    this._printData[id].featureCount, this.nls.reportsTab.notApplicableText);
                  break;
                case "esriGeometryPolyline":
                    this._printData[id].featureCount, this.nls.reportsTab.notApplicableText,
                    summaryTableMeasurement);
                  break;
        } else {
Martin,
      dataForReport = [];
        aoiTextTemplate =
          // Title
          "</div>" +
          // Area
          "</div>" +
          // Date
          "</div>" +
          "</div>";
      } else {
        aoiTextTemplate =
          // Title
          "</div>" +
          // Area
          "</div>" +
          "</div>";
      aoiText = {
        title: "",
        type: "html",
      printMap = {
        addPageBreak: true,
        type: "map",
        map: this.map,
        "type": "note",
        type: "table",
        data: {
          "maxNoOfCols": 4,
          "rows": [],
        impactArray = [];
        // no results found
          // fields off
            matchedIndex = [];
            aggregatedObj = {};
                break;
              "rows": [],
                case "Feet":
                  break;
                case "Miles":
                  break;
                case "Meters":
                  break;
                case "Kilometers":
                  break;
                case "Hectares":
                  break;
              reportTable = {
                title: data.title,
                type: "table",
                case "Feet":
                        places: 2
                  } else {
                  break;
                case "Miles":
                        places: 2
                  } else {
                  break;
                case "Meters":
                        places: 2
                  } else {
                  break;
                case "Kilometers":
                        places: 2
                  } else {
                  break;
                case "Hectares":
                        places: 2
                  } else {
                  break;
              } else {
                } else {
                  break;
                  break;
                  break;
        } else {
MartinOwens1
Thanks Robert. Yeah it took me forever to find that area. I actually ended up doing an if else statment  for the lines that push the column titles and values:
and this line:
and used the title to be able to skip those layers
      if(data.title === "Nearest Park" || data.title === "Countywide Soil Preservation Map" || data.title === "Inset Maps")
KrisRobbins2
Martin...could you possibly elaborate on this a  little further?  I need to completely remove the Area and Length calculations for all features in the report but am new to working with the code directly.
Any help would be much appreciated.
MartinOwens1
KrisRobbins2  my purpose was to only remove the area and length from certain layers in the report. For what you're asking for you just need to comment out a bunch of code:
        type: "table",
        data: {
          "maxNoOfCols": 4,
          "rows": [],
          "cols": [this.nls.common.name/* ,
          this._getAggregatedColTitle("esriGeometryPolyline") */ ]
        impactArray = [];
        // no results found
          // fields off
            matchedIndex = [];
            aggregatedObj = {};
                break;
              "rows": [],
           // aggregatedData.cols.push(this._getAggregatedColTitle(this._printData[id].geometryType));
			  /* selectedUnitValue = this.analysisUnitSelect.get('value');
                case "Feet":
                  break;
                case "SquareFeet":
                    this.getSum(this._printData[id].squareFeetUnitInfo,
                  break;
                case "Miles":
                  break;
                case "Acres":
                    this.getSum(this._printData[id].acresUnitInfo,
                  break;
                case "Meters":
                  break;
                case "SquareMeters":
                    this.getSum(this._printData[id].squareMetersUnitInfo,
                  break;
                case "Kilometers":
                  break;
                case "SquareKilometers":
                    this.getSum(this._printData[id].squareKilometersUnitInfo,
                  break;
                case "Hectares":
                  break;
                case "SquareMiles":
                    this.getSum(this._printData[id].squareMilesUnitInfo,
                  break;
                case "Count":
                    this.getSum(this._printData[id].countUnitInfo,
                  break;
              reportTable = {
                title: data.title,
                type: "table",
              /* switch (selectedUnitValue) {
                case "Feet":
                      dojoNumber.format(this.getSum(this._printData[id].feetUnitInfo), { places: 2 });
                  } else {
                  break;
                 case "Miles":
                      dojoNumber.format(this.getSum(this._printData[id].milesUnitInfo), { places: 2 });
                  } else {
                  break;
                case "Meters":
                      dojoNumber.format(this.getSum(this._printData[id].metersUnitInfo), { places: 2 });
                  } else {
                  break;
                case "Kilometers":
                      dojoNumber.format(this.getSum(this._printData[id].kilometersUnitInfo), { places: 2 });
                  } else {
                  break;
                case "Hectares":
                      dojoNumber.format(this.getSum(this._printData[id].hectaresUnitInfo), { places: 2 });
                  } else {
                  break;
              } else {
                } else {
                  break;
                  break;
                    this._printData[id].featureCount, this.nls.reportsTab.notApplicableText ,
                  break;
        } else {
/*           impactArray = [data.title];
          //check if layer is not analyzed
          if (this._printData[id].isExceedingMaxRecordCount) {
            showUnableToAnalyzeText = true;
            //show * in layer title if exceeding max records
            impactArray[0] += " *";
            //in case of unable to analyze show blank in area/length col
            impactSummaryAggregatedValue = "";
          } else {
              impactSummaryAggregatedValue = this.nls.reportsTab.notApplicableText;
            } else {
              impactSummaryAggregatedValue = 0;
              impactArray = impactArray.concat(this._printData[id].featureCount,
                this.nls.reportsTab.notApplicableText, this.nls.reportsTab.notApplicableText);
              break;
                 impactSummaryAggregatedValue,  this.nls.reportsTab.notApplicableText);
              break;
                this.nls.reportsTab.notApplicableText ,  impactSummaryAggregatedValue  );
              break;
        if (impactArray && impactArray.length > 0) {
          impactSummaryTable.data.rows.push(impactArray);
      //add impact summary table after map in report
      if (showUnableToAnalyzeText) {
        // Add unable to analyze text in report only if layer(s) not analyzed
        unableToAnalyzeText = {
          title: "",
          type: "html",
          data: "<div class='esriCTUnableToAnalyzeText'> * " +
            this.nls.reportsTab.unableToAnalyzeText + "</div>"
        dataForReport.splice(3, 0, impactSummaryTable, unableToAnalyzeText);
      } else {
        dataForReport.splice(3, 0, impactSummaryTable);
      return dataForReport;
