Map service line symbology with arrows
2759
11-25-2015 11:38 AM
SalvatoreScimeca1
Hello All,
I added a map to Web App Builder that has line symbology with arrows pointing in various directions.  Web App displays the arrows as thick black lines, where as flex displayed them correctly.  Is there a way or a step I missed to be able to view these arrows?
Salvatore
RobertScheitlin__GISP
MVP Esteemed Contributor
Salvatore,
  If you are adding the specific layer to the web map as a featureLayer (i.e. http://yourArcGISServer/arcgis/rest/services/yourservice/MapServer/0) then cartographic line symbols like line decoration (i.e. arrows) are not supported. If you add the whole map service then ArcGIS Server will do the rendering and you will get the cartographic line symbols.
Salvatore,
   When you view the web map in AGOLs Map Viewer does the layer display correctly.
SalvatoreScimeca1
No
Salvatore,
SalvatoreScimeca1
Yes, Thank you!
