Layer list - inconsistent order compared to the local layer widget
2678
12-09-2015 02:54 PM
LefterisKoumis
I cannot get the order of the layers as setup in the config of the local layer widget to match the order on the layer list.  The example below shows the layers order is different. Any idea why?
RobertScheitlin__GISP
Lefteris,
   The order you place then in using the LL Widget is not significant as the JS API will always place FeatureLayers above other types.
Lefteris,
LefterisKoumis
Thank you. I must skipped reading it somewhere in the JS API docs.
This behavior will likely change in the 4.0 API
