How would I hide portions of the bookmark web app builder widget?
4156
05-19-2015 03:34 PM
BrandonKeinath1
Hi Robert,
I've been going back and forth with ESRI on my bookmark issues and it has led to BUG-000087557.  It seems to boil down to any changes that create a local cache prevent future changes to the bookmark widgets configuration being seen by the user.  They're working on a solution but until they do I need to prevent users from doing anything that would create the local cache.  In my thinking this would mean the delete button, the add a bookmark button, and, unfortunately, your search functionality.  If I can I'd prefer them to be hidden so that I can put them back in the future.
Brandon
RobertScheitlin__GISP
Brandon,
   I don't think my search portion would cause the cache issue so I think you just need code to hide the add bookmark portion.  Just add this to the style.css
.jimu-widget-bookmark .add-section{
  display: none;
Brandon,
  display: none;
BrandonKeinath1
Hi Robert,
Worked like a charm.  And I think you're right about the filtering not affecting the cache.  I used the inspect element to also hide the "Delete" button.  Thanks for your help!  I tried to branch into a new discussion to turn it into a question but can't figure it out.
Brandon
Brandon,
   I converted the discussion to a question now.
BrandonKeinath1
Thanks Robert,
How did you convert it to a question?  When I edited the discussion I didn't see it as an option.  I could have missed it though.
Brandon
Brandon,
   At the very top of the page there is a link for that.
