Hey there - I was wondering if there is any chance to have a filter function on layers which are dynamically added to a session e.g. by the GP widget (add result or uploaded shapefile as operational layers). I noticed, that functionality is limited for these types of layers. My desired workflow: upload and add a zipped shapefile (polygons, fields are NOT standardized and subject to change) --> use FILTER functionality within table widget (now grayed out) --> use selection as input for gp service. Uploading and adding the features as op. layer works fine - also opening the attribute table. I can use the selection widget for spatial selection - and I can use those selections as input for my GP. Filtering in the attribute table would be great because these filters wouldn't have to be preconfigured. Any ideas?
Thanks, Falko
So are you talking about the Query widget then? What exact version are you talking about?
1.2 Robert.
I just find out the solution. I only need to add all fields on the pop-up on the config file as you can see here (in bold):
"name": "Parcels",
"url": "http://...",
"filter": {
"logicalOperator": "AND",
"parts": [
"fieldObj": {
"name": "gid",
"label": "gid",
"shortType": "number",
"type": "esriFieldTypeInteger"
"operator": "numberOperatorIsNotBlank",
"valueObj": {
"isValid": true,
"type": "value",
"value": null
"interactiveObj": "",
"caseSensitive": false,
"expr": "gid IS NOT NULL"
"popup": {
"title": "Field1: ${field1} <br/>" "Field2 : ${field2}<br/> Field3 : ${field3}",
"fields": []
