is there any custom widget to dynamically change a render on a layer in the map, something like this:
Change attribute used for a renderer | ArcGIS API for JavaScript
or
Class breaks renderer with dynamic layer | ArcGIS API for JavaScript
Thank you
Fabio
Giuseppe,
I have not seen one.
Same here. Any widgets out there that let you flip the style on a layer, ideally using predefined styles.
This seems to be a good sample from the docs if anybody else is trying to do it:
Update legend text with renderer | ArcGIS API for JavaScript 3.26
I've done something like this. I created from scratch and used the symbol chooser class along with other api tools. I open the widget from the layerlist and send it the id of the layer to operate on. I'm not sure how to attach here sure how to attach here. I wanted to attach the folder.
