problems with hardware acceleration on windows 10 pc
1635
6
01-17-2018 03:29 AM
by Anonymous User
Not applicable
I have a windows 10 laptop that when I bring in tutorial data into ArcMap 10.2.1 from the editing exercise 1 it does not load and then bombs me out of the application.
I suspect this to be because I selected accept hardware acceleration but need to narrow this down as our IT department cant seem to disable hardware acceleration now I have selected to use it.
Any help would be much appreciated, or is there a specific install for windows 10 I should be using
Regards
DanPatterson_Retired
turn it off in arcmap options, then load your data
by Anonymous User
Not applicable
I have tried this but still crashes as might be another issue I a.m. thinking
perhaps your machine specs aren't up to scratch, or it is the arcmap version (10.2.1... I think it was retired, so you would have to troll the support site for legacy error messages)
by Anonymous User
Not applicable
When it exits do you know if it writes to any logs
by Anonymous User
Not applicable
Superb will try tomorrow when back at work
