Is there a geoprocessing tool that would create a line from a point to the closest line?
Here is my situation. I have about 14,000 meters in Service Connection layer and they were created by geocoding to an address point, then
snapping that point to the front of the parcel. I would like to have a python script (or any other way you can suggest) to create a line from the
meter point to the closest point on the closest water main. I realize that this can be done one at a time using the "Add Laterals at Connections"
tool in the Water Utility Network Editing toolbar in ArcMap, however I do not know how to use this tool to perform this function on 14,000 meters at once.
Thank you
Katy
OK. I answered my own question. Whoever made this addin is a genius !!. Just download the zipfile
and put the addin with the rest of your ESRI addins. This nice person even included a little how to video in the download !! Mr. mysorekar you saved my butt !!
Can you post a link to the zip file that contains the add-in?
Vince - the addin can be downloaded from here
http://www.arcgis.com/home/item.html?id=0a4892bd754146e48b87de2352cdf64d
