Setting Target Locations for Archydro with python
2249
12-17-2013 08:03 AM
BrendanQuigley
New Contributor II
Hi there, i'm sure there is a simple answer but I haven't been able to figure it out yet.
I am trying to script some archydro processing with python. I am using the ArcHydroTools.
I am getting errors about setting the target locations so I put these lines in my code.
RasterLoc = "C:/Users/Me/Documents/Project/ScriptHydro"
VectorLoc = "C:/Users/Me/Documents/progect/ScriptHydro/xArcHydro.gdb"
ArcHydroTools.SetTargetLocations("HydroConfig","Layers",RasterLoc,VectorLoc)
I am getting the following error.
  File "C:\Users\Me\Documents\Project\ScriptMethodPart2.py", line 20, in <module>
  File "C:\Program Files (x86)\ESRI\WaterUtils\ArcHydro\bin\ArcHydroTools.py", line 62, in SetTargetLocations
    raise e
ExecuteError: System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
   at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
   at ESRI.APWR.ArcHydroGPTools.AHSetTargetLocations.Execute(IArray paramvalues, ITrackCancel trackcancel, IGPEnvironmentManager envMgr, IGPMessages message) in C:\Builds\HydroSolutions\10.1_ArcHydro\Sources\ArcHydroTools\src\ArcHydroGPTools\AHSetTargetLocations.vb:line 434
Failed to execute (SetTargetLocations).
Does anyone know the proper way to set Target locations? I even exported model builder into python but it didn't work because I had to change it to use ArcHydroTools.
Thanks
ChristineDartiguenave
Use "\" instead of "/" in your paths.
Christine Dartiguenave
Esri Water Resources Team
BrendanQuigley
New Contributor II
Does ArcHydro specifically need backslashes?
In this case yes. The path is parsed looking for "\".
by Anonymous User
Not applicable
Is it still looking for "\" in 2017?
