New password for Arc Hydro ftp site - March 11 2014
19059
55
03-11-2014 12:50 PM
ChristineDartiguenave
Note the new password for the ftp site as of 03/11/2014:
User login:  ADSRiverHydraulics
Password changed to:  ADSRiver.2014
Christine Dartiguenave
Esri Water Resources Team
GwenZarko
Christine,
I have tried the new login and password and it will not allow me access to get it.  I need the version that will work with 10.2.
Can you possibly help me out?
Thanks.
Gwen
V_StuartFoote
MVP Frequent Contributor
Gwen,
Just checked, the site is up and reached using credentials noted.  Have another go...
Stuart
ManishShrivastav
I cannot login. I am using filezilla.
The problem is that the site will get locked for a while if the wrong password is used too many times.
It should unlock in a little while. As an alternative, you can go the following location for download. Both locations are synchronized.
http://downloads.esri.com/archydro/archydro
V_StuartFoote
Manish Shrivastav‌,
Just verified that the MFT site is up and functional, please verify your sftp configuration as at the top of this thread--and try again.
Alternatively, the Water Resources Team has put up an HTTP service here. As announced by Christine in Alternate Download Location for Arc Hydro Setup Files
Stuart‌
SarahSeamands
Is there a tutorial or instruction manual to go with the ArcHydro Tools_x64 from your ftp site? This is the first time I have downloaded it, so I have a bit of learning curve. I'm using ArcGIS 10.2.
Thanks!
Sarah
