Need to make channel cross-sections
6132
09-25-2012 01:50 PM
RalphFinch
New Contributor III
This surely has been done before, so I just need to be directed to a forum thread or help topic area.
I have a functional surface (2m or 10m DEMs) which represents channel bathymetry (in the California Sacramento-San Joaquin Delta), and streamlines which represent the best centerline down each channel.
What I'd like to do is generate editable cross-sections at user-selected places on the streamlines. That is,
  1. User clicks a point somewhat away from a streamline and moves the mouse; ArcMap draws a cross-section line perpendicular to the streamline.
  2. User double-clicks or right-clicks to finish the cross-section line.
  3. ArcMap draws a channel cross-section profile: the elevation of the bathymetry along the cross-section line.
  4. User edits the generated cross-section profile. Somewhere here the user selects vertices to define a simplified cross-section profile for further use in a 1D numerical surface flow model.
  5. User clicks a button to finish editing.
  6. After all cross-sections are done the simplified cross-section profiles are saved to a text file for use in the 1D model.
I'm able to draw a cross-section profile using Interpolate Line -> Profile Graph within 3D Analyst. But the profile graph is not readily editable, nor does it look like it can be saved as data. So I'm looking for a hint as to where I can get the added editing capability listed above.
TroySpjute1
New Contributor II
The cross section editing functionality is built into HEC-RAS.  If you use the HEC GeoRAS extension you can easily export cross sections and other data for use in HEC-RAS, which also does the 1D modeling that you mentioned.
You can get information and download the extension (which is free) here:
http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html
MohamedJalloh1
Hi Ralph
I am working on something similar.However I have limited scripting knowledge can you please send me the script you have so far.
Thanks
Mohamed
DingaanJulyMahlangu
1 (sdsc.edu)
Visit this site it is very handy and help
DingaanJulyMahlangu
