This is the error:
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
Not sure if this is your problem, but have you tried checking your Target Locations under ApUtilities? I got a similar error when I accidentally left my Raster Data set to a Personal/File Geodatabase instead of a Shapefile/Raster Workspace. It's a pain in the butt, but you should probably check ApUtilitiesConfig / DefaultConfic / HydroConfig individually.
Actually that was the problem, I was able to solve by renaming the whole extension and never leave spaces in the name of the folders within the directory location. It takes me 3 weeks to know that after a lot of trials.
Glad you figured it out!
this worked for me! thanks a lot!
Thanks, @EllenFehrs. I too had the same problem and followed your advice. Now, it is resolved.
Failed to execute (DEMReconditioning).
error:
