HydroWatershed Analysis
2986
5
08-05-2015 04:33 PM
JJ6
Dear Esri Members,
I was attempting to conduct research on a section of the Amazon River Basin and was attempting to find connecting rivers, however, I am only able to see these connecting rivers once I zoom in. Take1.pngAbove is my computer image after I process my Digital Elevation Model->Perform the Fill Function-> and then run the Flow Accumulation Function.
Below is the image of DEM model.
I also wonder why the large Amazon river doesnt register as flow accumulation point in the model
DanPatterson_Retired
Ok, since your cell size is small and the area large, you are going to have to take some extra steps as shown in this link  How Flow Accumulation works—Help | ArcGIS for Desktop  then you may want to convert to a polyline using
Raster to Polyline—Help | ArcGIS for Desktop   or Stream to Feature—Help | ArcGIS for Desktop   if you have all the necessary data.
it is because of the colour ramp you are using, reverse it and/or change the black colour range to white
JJ6
Hey Mr.Patterson
I did think of that, and tried it
but as you can see you can barely see it...if I want to look at the DEM picture as a whole.
JJ6
You may also try to convert it to another color
Ex.
but this is even while zoomed in at (1:200,000)
I am also wondering why the actual Amazon river does not seem to register (the straight white line is where it should be)
NICOLAPEDDIS
Occasional Contributor II
Since the area river is very large, you need to additional steps like Dan wrote. Then try to reclass the Flow accumulation to se only the stream accumulation. reclass the raster[0 and 1]. Now if you want you can save the accumulation in the feature class with the tool Raster to Polyline
