How to burn stream in DEM?
2162
07-27-2022 07:42 PM
Labels (2)
Michiekoy
I've been working on matching the stream of my DEM on topo map. It got improve with the help of other contributors. I downloaded a stream network from openstreet map and processed it using DEM reconditioning. My stream improved but there are still out of the line streams which is minimal. I want to make it completely match the topo river stream by burning the DEM, unfortunately, I can't find any tutorial using ARCGIS.
SridhanabharathiBala
I'm facing a similar issue.  But I have not used open street map data instead i manually traced stream network in Google earth pro and trying to recondition DEM with it.  Could you help me if you have found the answer to your above question?
Thank you in advance
