Its saying your River file has a line that crosses a cross section more than once. In looking at your screenshot though I dont see where that is. Is it possible that you accidentally copied a cross section into your River file or the other way around? It gives you the ID numbers that are causing the issue so if that is not the case I would recommend just creating a new mxd and georas files then just copy your original data in.
