Bshihwa,
I had no issues moving systems to Desktop 10.2.2 and current HEC GeoRAS builds,
But, you would have fewer issues if you completely remove HEC GeoRAS, along with any other extensions to ArcGIS for Desktop, followed by a full uninstall of ArcGIS for Desktop, and finally clear your per-user profile and the Windows registry. E.g. get to a point where there is no Esri product on your system. And only then start with a clean ArcGIS for Desktop installation.
Stuart
Hi Stuart
Thanks a lot for your prompt response and advice. If I understood correctly, I need to uninstall previous Hec Georas, archydro, hec hms etc first and then after uninstalling arcgis 10.1 I should install fresh arcgis 10.2.2. After that Hec Georas 10.2.0.10 to get rid of issues.
Regards
Bishwa
Bishwa,
Your HEC RAS, or HEC HMS if installed, can remain. But the HEC GeoRAS preprocessor (and other Esri ApFramework based utilities, like ArcHydro Tools) will need to be uninstalled prior to the ArcGIS for Desktop install. It will then be replaced with a current build.
Doing it this way (removal of everything ArcGIS related) prevents issues during installation and setup.
Stuart
Thanks a lot!
Regards
Bishwa
Sent from my iPhone
I was wondering if you had any advice for using HEC with 10.3? I am just getting familiar with the software and wanted to incorporate it into my analysis but don't think the installer recognizes my version of 10.3.
Any advice is appreciated!
Best,
Jessie
I was wondering if you had tried this for 10.3 version. I am trying to get started working with HEC, but am not able to download the software with the new version of Arc.
Any suggestions are appreciated!
Best,
Jessie
