Failed to execute DEM Reconditioning (ArcGIS Pro 2.2.2 or ArcMap 10.6.1)
284
10-16-2018 05:28 AM
AbrinordOBV
New Contributor II
I am trying to use Arc Hydro tools Pro and it fails to execute DEM Reconditioning.
I also tried with ArcMap and it also fails.
 I am using ArcGIS Pro 2.2.2 and ArcMap 10.6.1
Thank you for your help.
Reply
ChristineDartiguenave
Send me the data and I will see whether I can reproduce the issue.
Christine
Reply
AbrinordOBV
New Contributor II
Where can I send you the data? they are not public data. Can we open a case?
Reply
I will send you a private box link.
Christine
Reply
AbrinordOBV
New Contributor II
There is not enough space to load the files
Reply
MarkBoucher
Regular Contributor II
I've had problems with DEM Reconditioning for a while and have had to create my own Model Builder Model to perform the task of burning streams and building walls.
Mark
Reply
