Solved! Go to Solution.
Install Visual Studio 2010 SP1 it resolve the issue
See this video may help you in your problem https://www.youtube.com/watch?v=DK34C7QScRU&feature=youtu.be
It looks like that video is no longer available. Can you perhaps offer some guidance on what it was about? I am having this issue and none of the solutions above have worked for me.
Jonathan, did you ever find the solution? I am encountering the same issue. Tried moving all data to C drive but still get the same error message: Error HRESLT E_FAIL has been returned from a call to a om Component
Using ArcMap 10.3.1 and ArcHydro, error is occurring at Catchment Grid Delineation step
My web search revealed little on this error.
It is basically the program "crying like a baby" and you have to guess what's wrong.
I think (and I could be wrong) the routine can't find any data to work with and says "Huh?" Then translates that into "HRESULT E_FAIL has been returned from a call to a COM component". If the processing extents don't coincide with the data, then this is what happens. This could be why things don't work well over the network (the link to the data gets scrambled). But then again, this is just my guess...
Check to see that your processing extent covers your data. Check/Set this in the menu "Geoprocessing>Environments>Processing Extent". On occasion, I've found that this fixes the problem.
LOL! “crying like a baby”. Tried your suggestions on processing extent but received the same error. ☹
However, I did get a good laugh thinking of my system crying like a baby.
