Calculate Length Downstream For Junctions Add Field Issue
3199
12-03-2014 01:52 PM
JoshObrecht
While trying to run the Calculate Length Downstream For Junctions tool, I receive the following error.
  File "C:\Users\444\Desktop\streams_final.py", line 49, in <module>
    ArcHydroTools.CalculateLengthDownstreamForJunctions(PlacedPoints)
  File "C:\Program Files (x86)\ESRI\WaterUtils\ArcHydro\bin\ArcHydroTools.py", line 255, in CalculateLengthDownstreamForJunctions
    raise e
ExecuteError: AddFieldGPerror : System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
   at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
   at ESRI.APWR.ApHydro.GDBHelper.AddFieldGP(ApLayer apLayer, String fieldTag, String& exMessage) in C:\Builds\HydroSolutions\10.2_ArcHydro\Sources\ArcHydroTools\src\ApHydro\GDBHelper.vb:line 1339
Failed to execute (CalculateLengthDownstreamForJunctions).
I am running the tool against a Feature Class. Can anyone tell me how to resolve this issue?
Tags (1)
JoshObrecht
Any help would be great
MarkBoucher
Regular Contributor II
Josh,
I've posted several "solutions" to Arc Hydro problems at ArcHydro Problem Solvers‌. You can peruse this for other solution ideas.
The "HRESULT E_FAIL" type error could be due to two things (my best off the top of my head guess).
  • Having your project files on a server. Put them on your local drive - runs faster and with fewer errors like this.
  • Put as much of your data as possible in geodatabases. They are more stable than regular shape files.
Mark
JoshObrecht
I will look in that thread to see if it helps. Both of your suggestions were already being done.
JoshObrecht
There was nothing in that thread that helped.
