Arc Hydro ArcGIS Pro - Longest Flow Path Snap Raster Error
1558
01-23-2022 01:07 PM
Jimmy_Simpson
I receive the following error when running several of the longest flow path tools (for catchments, for sub-watersheds, etc.) in ArcGIS Pro.
('line 218', 'c:\\program files\\arcgis\\pro\\Resources\\ArcToolbox\\Scripts\\archydro\\longestflowpathforcatchments.py', "AttributeError: 'GPEnvironment' object has no attribute 'SnapRaster'")
Any help would be appreciated. Currently I am having to take my FCs and run longest flow path in ArcMap and then move back to Pro.
Tags (1)
2 Solutions
DanPatterson
MVP Esteemed Contributor
open up the script and see how they set the snap raster
arcpy.env.snapRaster
is correct, it may be a capital S vs a small s issue in the script.  If it is, report it to the archydro people, I don't have it installed to check the script myself
Snap Raster (Environment setting)—ArcGIS Pro | Documentation
env—ArcGIS Pro | Documentation
... sort of retired...
Jimmy_Simpson
Yes - Line 218 of the Longest Flow Path for Catchments is written as "SnapRaster" instead of "snapRaster" - Making this change allowed the script to run without error.
Arc Hydro team - please make this change on all Longest Flow Path scripts as I believe most if not all of them contain this error.
@DanPatterson - Thank you for solving this so quickly - its greatly appreciated!!! I also use your Numpy tools quite frequently so thank you for all you do!!!
DanPatterson
Jimmy_Simpson
Dan,
You hit the nail on the head I believe. I see 10 lines before that "snapRaster" and in line 218 "SnapRaster" - going to try making a copy of their script with that one change and see if it works.
I would report it to the ArcHydro team, but have sent them a couple emails reporting issues and have never got a response back. Since I see them replying to questions in this group, I am hoping this post does some good.
Jimmy_Simpson
ZichuanYe
Yes, it should be arcpy.env.snapRaster and not .SnapRaster.   We'll fix the issue and produce a new build.
Thanks for catching this error, and @DanPatterson for your quick reply.
ZichuanYe
A new build with arcpy.env.snapRaster correctly set is posted at this location:
https://downloads.esri.com/archydro/archydro/Setup/Pro/2.9.13/
Please let us know if you have further questions
