Appropriate Threshold Value for Stream Network Delineation
96
3 weeks ago
Highlighted
I am creating stream orders for morphometric analysis.
At what threshold will we write to the Con tool when creating a stream? (Example "Value > 100").
As known this affects all accounts as it affects the number of Strahler stream orders.
How can I determine the threshold that I am going to write in the "Con tool" and that is suitable for my basin?
DEM data has been attached.
Best wishes, Ahmet.
Reply
Highlighted
MVP Regular Contributor
From the help topic, there is a reference link
Stream Order (Spatial Analyst)—ArcGIS Pro | Documentation
Tarboton D. G., R. L. Bras, I. Rodriguez–Iturbe. 1991. On the Extraction of Channel Networks from Digital Elevation Data. Hydrological Processes. 5: 81–100.
If you are associated with an academic institution, you can access the original here
https://onlinelibrary.wiley.com/doi/epdf/10.1002/hyp.3360050107
otherwise, it will be some $$ or you will have to Dr Google to see if anyone has covered the salient points in other links
sort of retired...
Highlighted
Thank you.
Reply
Highlighted
Reply
