def FindLabel ( [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT], [POLE_PRIKEY] ): if long( [POLE_PRIKEY] ) = long( [POLE_PRIKEY] ): return [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT] + '\n' + [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT] + '\n' + [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT] else: return [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT]
Solved! Go to Solution.
def FindLabel([FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT], [POLE_PRIKEY]):
if long( [POLE_PRIKEY] ) == long( [POLE_PRIKEY] ):
labelText = '{0}\n{1}\n{2}'.format([FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT], [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT], [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT])
return labelText
else:
labelText = [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT]
return labelText There is no way I can think of to reference multiple rows as a single label using label expressions.
def FindLabel([QS], [TWP]):
val_list = []
keyField = "TWP"
keyVal = [TWP]
field = "QS"
fieldVal = [QS]
layer = "ats"
with arcpy.da.SearchCursor(
layer, field, "{0} = {1}".format(keyField, keyVal)) as cursor:
for row in cursor:
val1 = row[0]
val_list.append(val1)
returnVal = "\n".join(val_list)
return returnVal
I possibly found a way to do it. Not all that fast though. You'll have to change all the field names to your data. It will return a label for every feature populated by every item in your target field that match the key field value.
def FindLabel( [POLE_PRIKEY] , [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT] ):
val_list = []
keyField = "POLE_PRIKEY"
keyVal = [POLE_PRIKEY]
field = "FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT"
fieldVal = [FIBER_ASSEMBLY_UNITS_ASSEMBLY_UNIT]
layer = "TEST"
for row in cursor:
val1 = row[0]
return returnVal
