I'm working with a Network dataset (which I did not build). The dataset has restrictions that should not allow sidewalks to be traversed through construction areas, however, network analyst is inconsistent in creating routes around these areas, sometimes sending pedestrians through construction zones, along pathways that are noted as being restricted within the network dataset. However, if I add the construction polygons manually to the Polygon barriers within the network analyst window and test routes, all routes are correct. So, now I would like to be able to add my construction layer as a barrier within my python script. Is this possible?
Solved! Go to Solution.
Thanks for your input Melinda. We will follow through with ESRI.
