Why can't i see tif image on arcmap 10.2.2 propably made in arcmap 10.0.0 how can i fix it
1248
01-19-2018 05:27 AM
Even in zoom to layer i cant see the tif image but i can see normaly the jpg images (the tif was made in arcmap 10.0 or 10.2.0 and i'm working on arcmap 10.2.2)
DanPatterson_Retired
you probably added it to a dataframe that had other data... in which case, perhaps the image is missing a projection file to define its coordinates, or perhaps it differs from the other data.
It would be best to 'Insert, Dataframe' and add just that one file to it to see if it shows at all.
Also, things like jpg and tif files often have *.jgw or *.tfw or *.aux files associated with them... you need them all in the same folder if you copied the image from somewhere else.
Ok I'll try it and hope it works out. Thank you Dan
Στις 19 Ιαν 2018 3:45 μ.μ., ο χρήστης "Dan Patterson" <geonet@esri.com>
έγραψε:
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: Why can't i see tif image on arcmap 10.2.2 propably made in arcmap
reply from Dan Patterson
<https://community.esri.com/people/Dan_Patterson?et=watches.email.thread>
in Training in GIS - View the full discussion
<https://community.esri.com/message/743244-re-why-cant-i-see-tif-image-on-arcmap-1022-propably-made-in-arcmap-1000-how-can-i-fix-it?commentID=743244&et=watches.email.thread#comment-743244>
