Where is the Parcel's Block and Lot information saved in the LGIM schema?
2890
04-26-2013 08:11 AM
DimitarKolev
Is there a Feature Class that holds the parcels' Block and Lot number in the ESRI Local Government Information Model (LGIM) geodatabase schema.
Under the "ParcelPublishing" dataset there is a "Block" polygon feature class, but I don't see Block and Lot fields in it.
Does LGIM schema provides parcel's Block&Lot numbers information or I have to create new attribute table to store it?
BettyConces
You can also find it in the Parcel Editing datasets (ParcelFabric_Parcels) within the LGIM....as a Type '6'. There is a 'Name' field for the Lot numbers (alias 'Lot or Unit Number' field) and a 'BlockDesignator' field (alias 'Block Number' field).
Hope that helps 🙂
