I have spent some time this month trying to understand how the Citizen Problem Reporter solution works There are a lot of basic questions I had that I couldn't find answers to on the Get Started page or elsewhere on the world wide web.
I thought I'd share some of the answers I've figured out with the automated deployment of the Citizen Problem Reporter Solution and see if anyone else has other questions/solutions!
Question | Answer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Why do I only see "Configured group is invalid or no items have been shared with this group yet." on my Reporter application? | This has to do with the fact that the configured group does not contain at least one map with at least one editable layer that is accessible to the current user. If the group does contain an editable map with an editable layer, then check the sharing. It may be that you haven't updated the sharing of the group or if you have, perhaps you are not Signing In with the proper account -- Sign in with ArcGIS if it isn't shared publicly. I kept trying to sign-in as Guest longer than I care to admit. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Why can't I see the image tab on a selected report in the Citizen Problem Manager? | This tab is only visible when the selected report contains at least one image attachment, or images and charts defined as part of the popup configuration. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Why can't the user attach photos to reports? | Attachments aren't enabled. When you do this process automatically, the layers are automatically uploaded to AGO. The attachment section of the form where photos and other supporting files can be added to the report is only available when attachments are enabled on the layer. This can be easily done by going to the feature layer in AGO and clicking "Enable Attachments". | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How do I add fields in the form of the Reporter? |
How do I delete fields in the form of the Reporter? | Open ArcGIS Pro. Add the Report Layer or Comment Table that the field is located in | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How do I turn off fields in the form of the Reporter? | If you don't want to display a field, but you aren't ready to delete it, go to the AGO web map that the layer is on. Go to Configure Pop-Up and then click Configure Attributes and just uncheck the Display. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Why can't the user edit the fields in the form? | First, when you are creating the field in the Configuration Task via ArcGIS Solutions, it's vital that you give the field a Field Length. The other issue may be that editing isn't enabled on the layer or in the pop-up. When you are in the AGO web map, Configure Pop-Up and then click Configure Attributes and ensure that the Editing box is checked in addition to the Display check box. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How can manipulate how every report/comment looks? | As far as I can't tell, you can't change the look of the form itself. However, once the report/comment is posted, you can change how this looks. This again happens in the AGO Web Map layer pop-up. When you go to Configure Pop-Up you have a few options. Under Pop-up Contents --> Display dropdown, change it to A custom attribute display --> then CONFIGURE. Here, you can add your own text and pull information from the report/comment fields (by clicking the + box; see image below). Scroll to the bottom where it says Pop-up Media. Here you can add a standard image/chart to all of the posted reports/comments. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How do I change colors and text in the Reporter? IMPORTANT NOTE: it is highly recommended that when these changes are made to Reporter maps/layers/applications, they are also made to the respective maps/layers/applications in the Manager for consistency and clarity purposes. |
Do you have other solutions or questions? I'd love to hear them!
Does anyone know where you set up the default values for the "Category" field in the Citizen Problem Reporter?
I had to create my own views of "Citizen Problems" so that I could update the domains on the views. I tried to copy all the settings using the Views and Maps that were deployed with the solution but I can't seem to figure out why when I add a point using the Reporter App, it's not displaying the point because the "Category" field is blank. When I look at one of the Views that was created with deployment there is no default value set....how does it get in there?! When I add a untouched map from the deployment it works, but if i try to add one that I modified it doesn't. I have too be missing a setting somewhere but I can't seem to find it! Any thoughts anyone?
Ashlie
Hi Ashlie,
The Crowdsource Reporter application uses the editing feature template associated with the layer to set the default value when creating a new feature. So you will need to update the view's feature template to set the default value for the Category field. To do this:
-Chris
Hi Chris -
Thank you for the suggestion. Yes I have looked at the options under the symbology. The views that are created with the deployment have this Edit Template that I can see that looks like an "Location only template" If I look at the JSON I can see that it has the Default Values for "Category", "Public View" and "Status". However, it is also displaying them by "Status". I can't seem to figure out how the Edit template is different from the Style. Style is set to display by "Status", but under the edit tab it shows a single black dot and I can't see or modify the properties.....
I can't seem to replicate this when I create a new view from the original Citizen Problems hosted layer. If I change the Style to view by Status the edit template changes as well. If I try to update the Defaults for the "Submitted" Style to include the Category it doesn't work.
Ashlie
Hi Ashlie,
Yes, the web map viewer makes this a little confusing. It will override the feature templates defined on the layer in the feature service to match the symbology in the map. Citizen Problem Reporter, however, will honor the template defined on the layer in the feature service. So you can temporarily change the symbology in the web map to single symbol just so you can edit the feature template on the service, you can then change the symbology back without impacting the feature service template and Problem Reporter should behave as expected.
If you would prefer this is actually easier to do through the REST admin api on the feature service:
"templates" : [
"name" : "Problem Report",
"description" : "",
"drawingTool" : "esriFeatureEditToolPoint",
"prototype" : {
"attributes" : {
"category" : "My Category",
"publicview" : "Yes",
"status" : "Submitted"
I have also been wanting to publish this solution out for my community, but have been left in the dark as well when trying to find information on how to set it up properly. I think ESRI needs to start publishing more step by step instructions on how to set up these solutions, instead of having people struggle with them. These solutions can be of great help, but there needs to be more tutorials either in written form or via Youtube. Sorry had to vent a little, lol! Come on ESRI, you can do better than this!
Hi Kate,
This post is very helpful for someone (like me) just started to use the Reporter!
Is there anyway to change the background image for the start-page. currently it is a cityscape showing downtown buildings. I am intended to use the Report for a rural area and preferred to use a picture of countryside. I flipped trough the configure pages and did not found a place to change the background image. I noticed that the image is stored as "https://www.arcgis.com/apps/CrowdsourceReporter/images/signinbg.png". However, I don't know how to change it?! Is it possible to change it and how?
Ming
Hi Ming Zhang follow the instructions here to change the splash screen. https://doc.arcgis.com/en/web-appbuilder/create-apps/widget-splash.htm
Hi Rebecca, I tried it yesterday and it works. Thanks!
Ming
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
How do you change the problem types on the Citizen problem reporter. When deployed using the solution deployment tool, the primary feature layer does not have a domain on the problem type field however the hosted views that are created each have what appears to be a domain or list of problem types.
Hi Brian,
It is possible to change the domains of hosted feature layer views, but it is not exposed in the ArcGIS Online UI yet. We provide a Modify Domains tool with the ArcGIS Solution Deployment add-in in ArcGIS Pro that can be used to do this. This process is described in the Modify problem types and responsible agencies below:
