Finding Activities is not using the address that you entered, it keeps stating Current Location not found. Has anybody found a work around to allow the address entered to be used by the activity.
Solved! Go to Solution.
Hi Joseph,
Do you see this issue in all browsers or Google Chrome only?
-Lindsay
Hi Joseph,
-Lindsay
You are right it does work different in Firefox then Chrome. Ok I see that it does work in Firefox from the location that Your IP provider gives you.
So this points to another problem, that I am working on fixing. If you search for your address then look for an activity it uses the location that your IP provider returns. Which for me is centroid of the City of Fontana, which happens to be about a mile from my location. So I would like to store the point or address as the known location. Instead of the IP location.
Thank you Lindsay
