Seting the newest Election Polling Places
2906
07-30-2013 09:47 AM
RafaelFernandez1
I downloaded the election-polling-places-625ecfc8bc2eb9b10882ca5d1cfa1379f251389c app.
[ATTACH=CONFIG]26322[/ATTACH]
But when I try to see it working for testing, nothing happen. I only can see the bar progress. Any suggestion?
Thanks!
RafaelFernandez1
Hi Mike,
I found the mistake.
I tried starting from local, without using IIS because I had it switch off. Now, you can see it works great in 10.2 release:
[ATTACH=CONFIG]26351[/ATTACH]
Thanks for your time.
Rafael
MikeTschudi
Hi Rafael,
Which version of Election Polling Places did you download?
If it was 10.1, did you see the 10.1 setup instructions; if it was 10.2, which came out today, did you see the 10.2 setup instructions?
The downloads do not come with services. You can point them to our try-it services to test the download, and then re-configure the apps to point to your services. As an example, the js/config.js file for the 10.2 version is attached.
Regards,
Mike
RafaelFernandez1
Hi Mike,
Firstly, thank you for your quick reply. I appreciate that.
I am using the config.js file you offered me. I modified the proxy.config as well:
<serverUrl matchAll="true" url="http://tryitlive.arcgis.com/arcgis/rest/services/GeneralPurpose/MapServer"></serverUrl>
        <serverUrl matchAll="true" url="http://tryitlive.arcgis.com/arcgis/rest/services/ImageryHybrid/MapServer"></serverUrl>
but when I try it again (default.html in local), I got this:
[ATTACH=CONFIG]26339[/ATTACH]
I think I am losing something.
Rafael
RafaelFernandez1
Hi Mike,
Rafael
