Parks and Recreation Finder - Circle Color
3323
10-08-2014 08:46 AM
EddBlaine
New Contributor III
By default, this app places a black circle around the park point when selected. I just want to change the circle it uses from black to red, so it will show up better on an aerial backdrop. I believe I've found the place to change it - locator.js line 1,329. Here is the line of code that I believe needs to be changed in order for the circle color to change:
var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, locatorRippleSize,
My problem is that I'm not sure how to change it. Any help would be appreciated!
LuciHawkins
Occasional Contributor III
at the very end of line 1329 you will see:
, new dojo.colorFromRgb(GetStylesSheet(".RippleColor")), 4), new dojo.Color([0, 0, 0, 0]));
The color is determined by   [0, 0, 0, 0]   at the end of the line.
Change it to    [255, 0, 0, 0]       for it to be a RED circle
Luci
LuciHawkins
Luci
EddBlaine
New Contributor III
Thanks for your response Luci! I think that you are right but for some reason, after making the change and saving it, the circle remains black...
E.
LuciHawkins
There are also circle symbols defined on line 626 and line 704 of the locator.js file.  Change it those two places and see if it changes the circle color.
Luci
