Local Govt Model - Line Flipping
270
01-23-2013 09:09 AM
ForrestPengra
New Contributor II
Hello All...
I've been using the LGM for a bit now.  Today however I 'finally' found out about the Infrastructure Editing Tools and the Attribute Assitant.  As part of this, I am now using the map provided with the package:
http://www.arcgis.com/home/item.html?id=14bdfb26bc2f4e0388a633fbd0ccca02
Now here is my problem.  I am trying to edit some lines and I'm getting errors like the following:
"FlipLines   The spatial references do not match"
And when I turn on the flow arrows I get:
"The spatial references do not match"
I'm in NAD83 - UTM17 the map was in a Illinois projection when it came from ESRI.
Does anyone have any idea how I can remedy my situation?  Up until I decided to use this MXD everything worked fine.  I'm thinking it has something to do with the tools but I'm not sure.
Thoughts?
FP
MikeMillerGIS
Esri Frequent Contributor
Forest,
   I have not seen this before.  Is the data and the mxd in the same projection?
