Label feature with two field attributes AGOL
590
10-28-2019 12:07 PM
by Anonymous User
Not applicable
Is there a way to label features with two field attributes in AGOL? I would like them to be displayed at different visibility ranges. I have a hosted layer for a cemetery with numerous grave plots. Zooming in to a certain range their grave IDs appear as labels. I want to display an owner/occupant field in addition to the grave ID after zooming in another two ranges. Ideally I would like them to be one on top of the other. I've tinkered around a bit but haven't figured out a way. Has anyone else had an issue like this? Any suggestions would help. Thanks.
AshokVanam1
Hi Daniel,
Duplicate the layers and enable the label on each layer with different respective fields.
in respective label field layer, set the visibility.
Regards
Ashok
Esri Australia
